    Are you working from home?
HP Notebook - 14-cf0020nf Product Specifications
4PM17EA
Intel® Core™ i3 7020U (2.3 GHz base frequency, 3 MB cache, 2 cores)
Intel® Integrated SoC
8 GB DDR4-2133 SDRAM (2 x 4 GB)
Video graphics
Intel® HD Graphics 620
  • 128 GB M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
35.6 cm (14") diagonal HD SVA micro-edge WLED-backlit (1366 x 768)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI 1.4b. 1 RJ-45; 1 headphone/microphone combo
32.4 x 22.59 x 1.99 cm
1.51 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 30 minutes
Video Playback Battery life
Up to 12 hours and 45 minutes
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP JumpStart
Pre-installed software
Netflix
