The Wireless Wide Area Network (WWAN) does not automatically reconnect. This is occurs after the computer restarts, or resumes from sleep or hibernation.
- ${title}
- ${title}
- ${title}
- ${title}
Document ID: c06293725
Version: 1
HP EliteBook x360 830 G5 Notebook PCs - WWAN Status Shows Disconnected After Computer Restarts
Release date : 08-Apr-2019
Last updated : 08-Apr-2019
The information in this document applies to the following:
Accessories:
HP lt4210 4G module
Firmware versions affected:
All
Computers:
Operating Systems:
Microsoft Windows 10 RS5 (Version 1809)
To resolve this issue, download and install the latest Windows Updates.
Click Start.
Select Settings.
Select Update & Security.
Select Check for updates.
Allow the Windows Update to download and install the updates.
Restart the computer.
Go back to Windows Update and select View update history.
Confirm KB4482887 is installed.
Close Windows Updates.
Hardware platforms affected :
Support Communication Cross Reference ID : IA06293725
© Copyright 2022 HP Development Company, L.P.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
