    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP P174 17-inch Monitor Product Specifications
Panel
5RD64AA
Display panel type
TN with LED backlight
17"
Panel active area (W x H)
33.79 × 27.03 cm
Resolution
SXGA (1280 x 1024 @ 60 Hz)
Aspect ratio
5:4
Viewing angle (typical)
160° vertical; 170° horizontal
Brightness (typical)
250 cd/m²
Contrast ratio (typical)
1000:1 static; 10000000:1 dynamic
Response times
5 ms on/off
Pixel pitch
0.264 mm
Display features
Anti-glare; LED backlights; On-screen controls; Plug and Play
Onscreen controls
User controls
Brightness; Color control; Contrast; Exit; Image control; Information; Management; Menu; Power
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
VGA
Display Input Type
1 VGA
Ergonomics
Tilt and swivel angle
Tilt: -5 to +25°
VESA mount
VESA mount compatible
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
179 W (maximum), 141 W (typical), 0.5 W (standby); 13 W (maximum), 12 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
37.48 x 19 x 38.59 cm
Dimensions (W x D x H)
37.48 x 5.07 x 31.23 cm
14.76 x 1.2 x 5.98 in
Product dimensions with stand (W x D x H)
14.76x 7.48 x15.19 in
2.6 kg
What's in the box
What's in the box
AC power cord; Documentation; VGA cable; QSP
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% RH
Environmental
Arsenic-free display glass; Low halogen; Mercury-free display backlights; TCO Certified
Certifications and compliances
Argentina S-Mark; Australia MEPS; BIS; BSMI; CB; CCC; CE; CEL; China CECP; cTUVus; E-standby; FCC; ICES; KC/KCC; KCC; RCM; SEPA eco label (China); Taiwan Green Mark; TCO Certified; TUV LBL; TUV/GS; VCCI; Vietnam MEPS; ISC; IEC 62368; California Energy Commission (CEC); Mexico safety; ES7.1
