Model name
HP Laser 107w
4ZB78A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP Laser 107w (4ZB78A)
Product naming
What's included and accessories
What's in the box
Preinstalled introductory HP LaserJet Black print cartridges (~0.5K pages, WW); Setup Guide; Reference Guide; Regulatory Statements Flyer; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port, Wireless 802.11 b/g/n
Wireless capability
Yes, built-in Wi-Fi 802.11b/g/n
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
20 to 70% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 27°C
Recommended operating temperature range (Fahrenheit)
59 to 80.6°F
Storage temperature range (Celsius)
-20 to 40°C
Storage temperature range (Fahrenheit)
-4 to 104°F
Environmental specifications
Mercury free
Memory
Memory
64 MB
Maximum Memory
64 MB
Memory card compatibility
None
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; Mobile Apps; Mopria™ Certified; Wi-Fi® Direct printing
Networking
Network protocols, supported
Via built-in networking solution: TCP/IP, IPv4, IPv6; print: TCP-IP port 9100 Direct Mode, LPD (raw queue support only), Web Services Printing; discovery: SLP, Bonjour, Web Services Discovery; IP Config: IPv4 (BootP, DHCP, AutoIP, Manual), IPv6 (Stateless Link-Local and via Router, Stateful via DHCPv6); management: SNMPv1/v2/v3, HTTP
Paper handling
Input capacity
Up to 150 sheets
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A5(LEF); B5 (JIS); Oficio; Envelope (DL, C5); 76 x 127 to 216 x 356mm
Media sizes supported (U.S. standard)
Letter; Legal; Executive; Oficio 216x340mm, Oficio 8.5x13 in, Envelope (No.10, Monarch); 4x6 in
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain, Thick, Thin, Cotton, Color, Preprinted, Recycled, Labels, CardStock, Bond, Archive, Envelope
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
331 x 350 x 248 mm
Maximum dimensions (W x D x H, U.S. standard)
13.03 x 13.78 x 9.76 in
Weight (metric)
4.16 kg
Weight (U.S. standard)
9.17 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Power save
Internal (built-in) Power Supply
Power supply
110-volt input voltage: 110 to 127 VAC, 50/60Hz and 220-volt input voltage: 220 to 240 VAC, 50/60Hz
Power consumption
320 watts (Active Printing), 33 watts (Ready), 1.1 watts (Sleep), 0.2 watts (Manual off), 0.2 watts (Auto off/Manual on)
Print cartridges
Number of print cartridges
1 (black)
Replacement cartridges
HP 105A Black Original Laser Toner Cartridge ( 1000 yield) W1105A; HP 106A Black Original Laser Toner Cartridge ( 1000 yield) W1106A; HP 107A Black Original Laser Toner Cartridge ( 1000 yield) W1107A
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 1,200 x 1,200 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 10,000 pages
Print languages
SPL
Printer smart software features
Manual duplex, N-up printing, collation, watermarks, accepts a variety of paper sizes and types
Regulatory specifications
Regulatory model number
SEOLA-1802-01
Safety
IEC 60950-1: 2005 +A1: 2009 +A2 2013 (International); EN 60950-1: 2006 +A11: 2009 +A1: 2010 +A12: 2011 +A2: 2013 (EU); IEC/EN 60825-1: 2014 (Class 1 Laser Product); EN 62479: 2010 /IEC 62749: 2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe); GS Certificate (Germany, Europe); UL/cUL Listed and UC CoC (US/Canada); CAN/CSA C22.2 No. 60950-1-07 2nd Ed. 2014-10; Compliance with Laser safety standards 21 CFR 1002.10 and 1002.11 except for deviations pursuant to Laser notice No. 50, Dated June 24, 2007; Other safety approvals as required by individual countries
Electromagnetic compatibility
EN 61000-3-2: 2014, EN 61000-3-3: 2013, EN55024: 2010, EN 55032: 2012/AC: 2013, 47 CFR Part 15, Subpart B I ANSI C63.4-2009, ICES-003 Issue 5, KN32, KN35, GB/T 9254-2008, GB17625.1-2012, CISPR22: 2008, CISPR32: 2012,CNS 13438 (Other EMC approvals as required by individual countries.)
Security
Security management
Password-protected network embedded Web server; enable/disable Network ports; SNMPv1 community password change; SNMPV2&V3; IPSec; Filtering : MAC, IPv4, IPv6
System requirements
Minimum system requirements for Windows
Windows 7 or newer, Intel® Pentium® IV 1 GHz 32-bit or 64-bit processor or higher, 1 GB RAM, 16 GB HDD
Compatible Network Operating Systems
Windows®: 7 (32/64 bit), 2008 Server R2, 8 (32/64 bit),10 (32/64 bit), 2012 Server, 2016 Server
Operating system (supported note)
Windows 7 or higher
One-year limited hardware warranty; For more info please visit us at https://support.hp.com
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
