HP LaserJet Pro MFP M329, M428-M429, M479 - Scan to a computer (Windows)
Use this feature to scan directly to a computer from the printer control panel. This feature is available for Windows only.
Before scanning to a computer, make sure you have already installed the HP recommended printer software. The printer and computer must be connected and turned on. The printer software must be running before you scan.
This feature is disabled by default. To enable the Scan to Computer feature, go to Set up Scan to Computer (Windows).
  1. Load the document on the scanner glass or into the document feeder according to the indicators on the printer.
  2. From the Home screen on the control panel, touch the Scan icon.
  3. Swipe right and then touch the Computer icon.
  4. Select the computer you want to scan to.
  5. Verify the Scan Shortcut is the option you want to use, or touch Scan Shortcut to select a different scan option.
  6. If you are using the automatic document feeder (ADF) and your original is single-sided, touch the left side of the Original 2-sided slider to move it to the off position.
  7. To select any additional scan options, touch the Settings icon .
  8. Touch Send or Start Scan.
