    Fix Windows 10 Update Issues
HP Pavilion 15-cs1010tu Product Specifications
6MY69PA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 620
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ (Data transfer only, 5 Gb/s signaling rate)
36.16 x 24.16 x 1.79 cm
Starting at 1.85 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
FreeDOS 1.2
