6HN22PA
HP Spectre x360 - 13-ap0127tu
Intel® Core™ i7-8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
8 GB DDR4-2666 SDRAM (onboard)
Video graphics
512 GB PCIe® NVMe™ M.2 SSD
HP Sure View Integrated Privacy Screen 13.3" diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
1 microSD and 1 nano-SIM combo
2x USB Type-C™ 3.1 Gen 2 (Thunderbolt™ 3, DP 1.2, PD 3.0, Data transfer, HP Sleep and Charge ); 1x USB 3.1 Gen2 Type-A™ (HP Sleep and Charge); 1 headphone/microphone combo
30.88 x 21.79 x 1.45 cm
Starting at 1.32 kg
65 W USB Type-C™ adapter
4-cell, 61 Wh Li-ion
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
HP Spectre x360 - 13-ap0127tu Product Specifications
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
