    Fix HP Printer issue on macOS
HP LaserJet Managed MFP E72425, E72430, E77422, E77428, E78223, E78228 - 13.B9 jam error in the right door and fuser area
Use the following procedure to clear paper jams in the right door and fuser area. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B9.Az Fuser Jam
  • 13.B9.Dz Jam in right door
  • 13.B9.FF Jam in right door
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in the right door and fuser area:
The fuser is hot while the printer is in use. Wait for the fuser to cool before clearing jams.
  1. Open the right door.
    Figure : Open the right door
  2. Gently remove any jammed paper from inside the right door.
    Figure : Remove jammed paper from inside the right door
  3. Close the right door.
    Figure : Close the right door
