HP Neverstop Laser MFP 1200 - Replacement Printer Instructions
This document is for HP Neverstop Laser MFP 1200a, 1200w, 1202w, 1200n, 1201n, 1200nw, and 1202nw printers.
When HP replaces your defective product, some accessories or parts need to be transferred from the defective product to the replacement product.
  • Some optional accessories might not be included with your product model.
  • Keep any optional accessories that you bought separately.
Follow these steps to make sure that you remove and keep the correct printer accessories before you send the printer back to HP.
  1. Turn the printer off, and then disconnect the power cord.
  2. Lift the scanner, and then open the top cover.
    Lifting the scanner and top cover
  3. Using the handle, pull the imaging drum up and out to remove it, and then set it aside.
    Do not touch the green roller. Fingerprints and smudges can damage the imaging drum and affect print quality.
    Removing the imaging drum
  4. Close the top cover, and then lower the scanner.
    Closing the top cover and scanner
  5. Tape the scanner lid closed.
  6. Remove the paper cover and the input tray.
    Removing the input tray cover and the input tray
  7. Pack the printer, paper cover, and input tray in a box that is large enough to hold the printer and packing material.
  8. Keep the following accessories to use with the replacement printer:
    • Imaging drum
      If you are not going to insert the imaging drum into the replacement printer immediately, put it into a plastic bag or box, and then store it in a cool, dry place out of direct light.
      Imaging drum
    • Toner Reload Kit
      Toner Reload Kit
    • Power cord
      Power cord
    • Universal Serial Bus (USB) cable
    • Printer software CD
      Printer software CDs
    • Printer user guide
      Printer user guide
  9. On the replacement printer, lift the scanner, and then open the top cover.
  10. Hold the imaging drum by the handle, shake it at least five times to loosen the toner, align it with the tracks, and then insert it into the printer.
    Inserting the imaging drum into the printer
  11. Close the top cover, and then lower the scanner.
  12. Insert the input tray into its slot.
    Installing the input tray
  13. Load paper, and then slide the input tray cover onto the tray.
    Loading paper and sliding on the input tray cover
  14. Connect the power cord to the rear of the replacement printer, and then plug it into a wall outlet.
    Connecting the power cord
  15. Turn on the replacement printer, and then test all printer functions.
  16. For additional printer support information, go to the HP Customer Support page.
