HP PrinterOn Enterprise - First Time Logging into the PrinterOn Configuration Manager
Logging into the the PrinterOn Configuration Manager is accomplished by using:
  • URL: https://127.0.0.1:8057 (default port, additionally access is only over https)
  • Username - root
  • Password - APIsiteAuth value found in your license file
Once you have connected successfully, password change screen will be presented to generate and save a new password for the root account.
The limitations on this password are:
  1. Username must not be present in password.
  2. Password must not have 4 or more consecutive letters or digits.
  3. If 8-9 characters it needs at least 1 letter, 1 number, and 1 special character.
  4. If 10+ characters, then two characters are needed from two of these three categories.
  5. Letters.
  6. Numbers.
  7. Special Characters.
Applies to PrinterOn Enterprise 3.x and later.
