HP Chromebook x360 14 G1 Specifications
Product image
Feature
Preinstalled
Chrome OS
Processors
Intel Core i7-8650U
1.9 GHz base frequency, up to 4.2 GHz maximum Turbo Boost technology
8 MB cache, 4 cores
Intel UHD Graphics 620
Intel Core i5-8350U
1.7 GHz base frequency, up to 3.6 GHz maximum Turbo Boost technology
6 MB cache, 4 cores
Intel Core i3-8130U
2.2 GHz base frequency, up to 3.4 GHz maximum Turbo Boost technology
4 MB cache, 2 cores
Intel Pentium 4415U
2.3 GHz base frequency
2 MB cache, 2 cores
Intel HD Graphics 610
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Turbo Boost performance varies depending on hardware, software, and overall system configuration.
Graphics
Feature
Integrated
High-definition (HD) content is required to view high definition images.
Supported
HD Decoder
DirectX 12
HDMI 1.4b
Feature
Internal
Touch
35.56 cm (14.0 in) diagonal FHD IPS eDP Brightview WLED-backlit slim-flat (3.0 mm) touch screen, 220 cd/m2, 67% sRGB (1920 x 1080) Narrow bezel
High definition content is required to view high-definition images.
Resolutions are dependent upon monitor capability, resolution, and color depth settings.
Storage and drives
Feature
Primary storage (supports eMMC SSD)
eMMC 5.0
32 GB
64 GB
For storage drives, GB = 1 billion bytes. Actual formatted capacity is less. 5.1 GB of the eMMC is dedicated/allocated to the Chrome OS partition.
Memory
Feature
Memory
8 GB DDR4-2133 SDRAM (8 GB x 1) onboard
16 GB DDR4-2133 SDRAM (16 GB x 1) onboard
Memory slots
Soldered down
Ports/slots
Specification
Ports
(2) USB 3.1 Type-C (Supports Power Delivery, charge and video support, and data transfer)
(1) USB 3.1 Gen 1 (Charging)
(1) Stereo Headphone/microphone combo jack
Slots
(1) MicroSD card
Supports SD, SDHC, and SDXC
Audio/multimedia
Feature
Audio
B&O Play
(2) integrated stereo speakers
Camera
720p HD camera
High definition content required to view high-definition images.
Keyboard/pointing devices
Keyboard
Full-sized, textured, island-style
Flint silver
Backlit
Pointing devices
Multi-touch gestures enabled
Taps enabled by default
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 7265 802.11ac (2x2) WLAN with Bluetooth 4.2 Combo, non-vPro
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Miracast
Miracast with the Intel 7265 ac WLAN
Software and security
Preinstalled software
HP Classroom Manager (sold separately)
Stores up to 100 GB with Google Drive (2-year subscription included)
Google Drive offer is tied to this device and is non-transferable. If this device is returned, the extra storage will be revoked. In order to redeem this offer, Chrome OS 23 or later needs to be installed. Internet access is required and not included. Additional information about storage plan refunds, renewals, cancellations, and expiration is available at the Google website.
Security
H1 Security IC
Nano Security lock slot (lock sold separately)
Power
Specification
Power supply
HP Smart 45 W USB Type-C straight type AC adapter
Availability might vary by country.
Power cord
Minimum 1.0 m (3.3 ft) length USB-C/power cord
Primary battery
HP Long Life 3-cell, 60.9 Wh Li-ion
Battery is internal and not replaceable by customer. Serviceable by warranty.
Battery weight
0.24 kg (0.54 lb)
Product features
Specification
Starting at 1.68 kg (3.7 lb)
Dimensions (W x D x H)
32.54 x 22.68 x 1.60 cm (12.81 x 8.93 x 0.63 in)
