HP Notebook 15-da1022tx Product Specifications
5NM12PA
Intel® Core™ i7-8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Video graphics
  • NVIDIA® GeForce® MX130 (2 GB GDDR5 dedicated)
  • Discrete
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion prismatic and polymer
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP JumpStart; HP Documentation; HP ePrint; HP Support Assistant
