    Are you working from home?
HP 24m 23.8-inch Display Product Specifications
Panel
3WL46AA
5SQ52AA
Display panel type
IPS with LED backlight
23.8"
Panel active area (W x H)
52.7 x 29.64 cm
Resolution
FHD (1920 x 1080 @ 60 Hz)
Aspect ratio
16:9
Viewing angle (typical)
178° horizontal; 178° vertical
Brightness (typical)
250 cd/m²
Contrast ratio (typical)
1000:1 static
Response times
14 ms gray to gray
Pixel pitch
0.274 mm
Display features
Anti-glare; Language selection; On-screen controls; Plug and Play; User controls; User programmable
Onscreen controls
User controls
Brightness; Color control; Contrast; Exit; Image control; Input control; Language; Management; Menu control; Power control
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; VGA
Ports
ERROR123
Display Input Type
1 HDMI 1.4 (with HDCP support); 1 VGA
Ergonomics
Tilt and swivel angle
Tilt: -5 to +20°
VESA mount
ERROR123
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
25 W (maximum), 22 W (typical), 0.3 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
54.27 x 18.9 x 41.9 cm
Dimensions (W x D x H)
54.27 x 3.75 x 33.05 cm
21.37 x 1.48 x 13.01 in
Product dimensions with stand (W x D x H)
21.36 x 7.44 x 16.5 in
2.84 kg
What's in the box
What's in the box
AC power cord; Documentation; HDMI cable; Power adapter; VGA cable
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Environmental
Arsenic-free display glass; Low halogen; Mercury-free display backlights
Certifications and compliances
Australian-New Zealand MEPS; BIS; BSMI; CB; CCC; CE; CEL Grade 1; C-Tick; cTUVus; EAC; Energy Star; E-standby; EUP Lot-6; FCC; ICES; ISO 9241-307; KC/KCC; MEPS; Microsoft WHQL Certification (Windows 10, Windows 8.1 and Windows 7); TUV Bauart; VCCI; Vietnam MEPS; WEEE; ISC; Low blue light; UkrSEPRO; South Africa MEPS; Ukraine Energy label
