HP Notebook - 15q-dy0001au Product Specifications
4XB40PA
AMD Dual-Core E2-9000e (1.5 GHz base frequency, up to 2 GHz burst frequency, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R2 Graphics
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
39.62 cm(15.6) diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
HP Webcam with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
