    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion - 15-bc495ur Product Specifications
4XX74EA
Intel® Core™ i5-8300H (2.3 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1050 Ti (4 GB GDDR5 dedicated)
  • 1 TB 5400 rpm SATA
  • 128 GB M.2 SSD
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Pointing device
802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.24 x 25.25 x 2.45 cm
2.2 kg
150 W AC power adapter
3-cell, 52.2 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
FreeDOS 1.2
