HP Pavilion 15-dp0094ur Product Specifications
5AS63EA
Intel® Core™ i5-8300H (2.3 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1060 (3 GB GDDR5 dedicated)
  • 1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.24 x 25.25 x 2.45 cm
2.22 kg
200 W AC power adapter
4-cell, 63.3 Wh Li-ion
Battery life mixed usage
Up to 6 hours and 45 minutes
Video Playback Battery life
Up to 5 hours
FreeDOS 1.2
