    Fix Windows 10 Update Issues
HP Notebook 15-da1005ur Product Specifications
5GZ41EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Pointing device
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.86 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 30 minutes
Video Playback Battery life
Up to 12 hours
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS 1.2
