HP 250 G7 Notebook PC Specifications
Product image
Operating systems
Feature
Preinstalled
Windows 10 Pro 64 (National Academic only)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i3-1005G1
1.2 GHz base frequency, up to 3.4 GHz with Intel Turbo Boost Technology
4 MB L3 cache and 2 cores
Intel UHD Graphics 620
Intel Core i3-1005G1 (with 16 GB Intel Optane memory)
With 16 GB Intel Optane memory
Intel Core i3-8130U
2.2 GHz base frequency, up to 3.4 GHz with Intel Turbo Boost Technology
4 MB L3 cache and 4 cores
Intel HD Graphics 620
Intel Core i3-8130U (with 16 GB Intel Optane memory)
Intel Core i5-1035G1
1.0 GHz base frequency, up to 3.6 GHz with Intel Turbo Boost Technology
6 MB L3 cache and 4 cores
Intel Core i5-1035G1 (with 16 GB Intel Optane memory)
Intel Core i7-1065G7
1.3 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost Technology
8 MB L3 cache and 4 cores
Intel Iris Plus Graphics
Intel Core i7-1065G7 (with 16 GB Intel Optane memory)
Intel Core i7-8550U
1.8 GHz base frequency, up to 4.0 GHz with Intel Turbo Boost Technology
8 MB cache and 4 cores
Intel Core i7-8650U
1.9 GHz base frequency, up to 4.2 GHz with Intel Turbo Boost Technology
Intel Pentium Gold Processor 4417U
2.3 GHz base frequency
2 MB cache and 2 cores
Intel HD Graphics 610
Intel Pentium Silver Processor N5030
1.1 GHz base frequency, up to 3.1 GHz burst frequency
4 MB cache and 4 cores
Intel UHD Graphics 605
Intel Celeron Processor N4020
1.1 GHz base frequency, up to 2.8 GHz burst frequency
4 MB cache and 2 cores
Intel UHD Graphics 600
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Feature
Integrated
Intel Iris Plus graphics
Intel HD Graphics 400
HD content required to view HD images.
Discrete
NVIDIA GeForce MX130 (2 GB DDR5 dedicated)
NVIDIA GeForce MX110 (2 GB DDR5 dedicated)
Integrated graphics depends on processor. NVIDIA Optimus technology requires an Intel processor, plus an NVIDIA GeForce discrete graphics configuration and is available on Windows 10 Pro OS. With NVIDIA Optimus technology, full enablement of all discrete graphics video and display features might not be supported on all systems.
Supported
HD decode
DirectX12
HDMI 1.4b
Feature
Internal
Non-touch HD (optional)
39.62 cm (15.6 in) diagonal HD SVA eDP anti-glare WLED-backlit, 67% sRGB, 220 cd/m² (1366 x 768)
Non-touch FHD (optional)
39.62 cm (15.6 in) diagonal FHD SVA eDP anti-glare WLED-backlit, 67% sRGB, 220 cd/m² (1920 x 1080)
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Supported resolutions (HDMI)
Up to 1920 x 1200 external resolution at 60 Hz
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB SATA-3 TLC SSD
256 GB SATA-3 TLC SSD
256 GB PCIe Gen 3 x4 NVMe Value SSD
512 GB PCIe Gen 3 x4 NVMe Value SSD
16 GB Intel Optane Memory Cache
Primary Hard Disk Drive storage
500 GB 5400 rpm SATA
500 GB 7200 rpm SATA
1 TB 5400 rpm SATA
Optional integrated Optical Disc Drive (ODD)
DVD Writer
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Intel Optane memory system acceleration does not replace or increase the DRAM in your system and requires configuration with an optional Intel Core (i3, i5 or i7)+ processor.
Memory
Feature
Standard
DDDR4-PC4 SODIMMS
Slots
With Intel 10th and 8th
(2) SODIMM slots (both slots are customer non-accessible/non-upgradable)
Supports dual-channel memory
Intel N5030 and N4020 processor
(1) SODIMM slot (slot is customer non-accessible/non-upgradable)
Supports single-channel memory
Memory speed
Maximum up to 2666 MT/s
Configurations
16 GB DDR4-2666 SDRAM (2 x 8 GB)
8 GB DDR4-2666 SDRAM (2 x 4 GB)
4 GB DDR4-2666 SDRAM (1 x 4 GB)
16 GB DDR4-2400 SDRAM (2 x 8 GB)
12 GB DDR4-2400 SDRAM (1 x 8 GB and 1 x 4 GB)
8 GB DDR4-2400 SDRAM (2 x 4 GB)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Maximum
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports/slots
Feature
Ports
(1) USB 2.0
(2) USB 3.1 Gen 1
(1) HDMI v1.4b (cable are sold separately)
(1) RJ-45/Ethernet port
(1) Headphone/microphone combo jack
(1) AC power port
Slot
(1) Smart card reader
Supports SD, SDHC, and SDXC
Networking/communication
Feature
Wireless LAN (WLAN)
Realtek 802.11ac (2x2) Wi-Fi and Bluetooth 5.0 Combo (MU-MIMO supported)
Realtek RTL8821CE 802.11ac (2x2) Wi-Fi and Bluetooth 4.2 Combo (MU-MIMO supported)
Realtek RTL8822BE 802.11ac (1x1) and Bluetooth 4.2 Combo
Realtek RTL8822BE 802.11b/g/n (1x1) and Bluetooth 4.2 Combo
Wireless access point and internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Miracast
Supported
Ethernet
Integrated 10/100/1000 GbE NIC
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Feature
Audio
(2) Integrated dual-array microphone
Integrated stereo speakers
Camera (optional)
HP TrueVision HD Camera
HD content required to view HD images. Internet access required.
Webcam (optional)
VGA webcam
Keyboards/pointing devices/function keys
Feature
HP Premium keyboard
Full size textured island-style keyboard with numeric pad
Pointing device
Touchpad with multi-touch gesture support enabled
Function keys
Function keys
F1 – Open 'How to get help in Windows 10' webpage
F2 – Brightness down
F3 – Brightness up
F4 – Display switching
F5 – Blank
F6 – Microphone mute
F7 – Volume down
F8 – Volume up
F9 – Previous
F10 – Play/Pause
F11 – Next
F12 – Airplane mode
Software/security
Feature
HP Value add software
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Documentation
HP Setup Integrated OOBE
HP Audio Switch
Security
McAfee LiveSafe
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Power
Feature
Power supply
Adapters
HP 45 W Smart External AC Adapter
HP 65 W Smart EM External AC power adapte
HP 65 W Smart External AC Adapter
Power cord
3-wire plug (C5), 1.0 m (3.28 ft)
Availability might vary by country/region.
Primary battery
HP 3-cell Long Life (41 WHr) Li-ion
Battery is internal and not replaceable by customer.
HP Fast Charge technology
Recharges the battery up to 90% within 90 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 watts is required. After charging has reached 90% capacity, charging returns to normal. Charging time might vary +/-10% due to system tolerance.
Battery life
Up to 12 hours and 30 minutes
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Battery weight
0.18 kg (0.4 lb)
Physical specifications
Feature
Starting at 1.78 kg (3.92 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
37.59 x 24.59 x 2.26 cm (14.8 x 9.68 x 0.89 in)
