HP ENVY - 13-ah1011tu Product Specifications
5HZ28PA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
8 GB LPDDR3-2133 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
1 microSD media card reader
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 headphone/microphone combo
30.7 x 21.2 x 1.49 cm
Starting at 1.21 kg
65 W AC power adapter
4-cell, 53.2 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center
Pre-installed software
iQiyi
