    Are you working from home?
HP Notebook - 15-db0022ns Product Specifications
3ZU61EA
AMD A9-9425 Dual-Core (3.1 GHz base frequency, up to 3.7 GHz burst frequency, 1 MB cache)
8 GB DDR4-1866 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ 520 Graphics (2 GB GDDR5 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Pointing device
802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
2.04 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 30 minutes
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
