    Fix Windows 10 Update Issues
HP PageWide Pro MFP 772, 777, HP PageWide Managed MFP P70000 series - Copy Small Media
This document contains information on how to copy small media in either a portrait or landscape orientation.
Small media are all sizes of media that cannot be loaded into the automatic document feeder, such as the following:
  • Checks
  • Shopping ticket or receipt
  • Cards
  • Small pictures
Since small media types are typically not handled well by the printer engine, they must be copied from the scanner glass and attached to a larger-sized media.
Small media can be copied in a landscape (horizontal) or portrait (vertical) orientation. Select the copy orientation based on the desired output.
The following sections contain explanations and recommendations for copying small media in either a landscape or portrait orientation.
