    Fix Windows 10 Update Issues
HP ENVY - 13-ah0046tx Product Specifications
4TA16PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
8 GB LPDDR3-2133 SDRAM (onboard)
360 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer, Disply Port 1.2, Power Delivery 3.0, HP Sleep & Charge); 1 headphone/microphone combo
30.7 x 21.2 x 1.49 cm
Starting at 1.21 kg
65 W AC power adapter
4-cell, 53.2 Wh Li-ion
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer; HP Command Center
Pre-installed software
iQiyi
