Document ID: c06102254
Version: 1
Advisory: HP Z240 SFF, Z240 Tower, Z238 Microtower - System Hangs at BIOS Post and/or Boot Device not Found
Release date : 01-Aug-2018
Last updated : 01-Aug-2018
DESCRIPTION
The system hangs or takes a long time to post to the BIOS and/or Boot Device not Found.
The issue might be caused by third-party display port cables.
SCOPE
Systems:
  • HP Z238 Microtower Workstation
  • HP Z240 Small Form Factor Workstation Bundle
  • HP Z240 Tower Workstation
Operating Systems:
  • Non-OS Specific
RESOLUTION
In some 3rd-party Display Port cables, a pin is connected that causes a power sequence issue. Certain HDD devices, mainly operating systems installed on M.2 NVME devices, can go missing.
Resolve the issue:
  1. Determine if you have a third-party display port cable.
  2. If your cable is from a third party vendor, replace it with an HP display port cable.
  3. If the new cable resolves the issue, replace the cables on the other affected computers with cables purchased from HP or another reliable source.
Hardware platforms affected : HP Z238 Microtower Workstation, HP Z240 Small Form Factor Workstation Bundle, HP Z240 Tower Workstation
Support Communication Cross Reference ID : IA06102254
