HP ENVY x360 - 13-ag0010ca Product Specifications
4BP95UA
AMD Ryzen™ 5 2500U Quad-Core (2 GHz base frequency, up to 3.6 GHz burst frequency, 6 MB cache)
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ Vega 8 Graphics
256 GB PCIe® NVMe™ M.2 SSD
33.8 cm (13.3") diagonal FHD IPS BrightView WLED-backlit micro-edge multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
1 USB 3.1 Type-C™ Gen 2 (Data Transfer up to 5 Gb/s, Power Delivery, DisplayPort™ 1.4, HDMI 2.0, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 headphone/microphone combo
30.67 x 21.46 x 1.49 cm
1.29 kg
45 W AC power adapter
4-cell, 53.2 Wh Li-ion
Bang & Olufsen, dual speakers
Pre-installed software
Netflix
