4BV99PA
HP Pavilion x360 - 14-cd0008tx
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
512 GB PCIe® NVMe™ M.2 SSD
14" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style keyboard
Pointing device
802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
32.35 x 22.42 x 1.97 cm
Starting at 1.59 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion prismatic
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion x360 - 14-cd0008tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP System Event Utility; HP Connection Optimizer
McAfee LiveSafe™ 30-day free trial offer
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
