HP ENVY x360 - 15-cn0020tx Product Specifications
4SU25PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
16 GB DDR4-2400 SDRAM (2 x 8 GB)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 2.0; 1 headphone/microphone combo; 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer, Disply Port 1.2, Power Delivery 3.0, HP Sleep & Charge)
35.9 x 24.6 x 1.89 cm
Starting at 2.04 kg
65 W AC power adapter
3-cell, 52.5 Wh Li-ion
Bang & Olufsen, dual speakers, HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect; HP Connection Optimizer; HP Command Center
McAfee LiveSafe™ 30-day free trial offer
Pre-installed software
iQiyi
