    Apache Log4j Update
HP ENVY x360 - 15-cn0009tx Product Specifications
4MD97PA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit touch screen (1920 x 1080)
Keyboard
Pointing device
Intel® Wireless-AC 7265 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 2.0; 1 headphone/microphone combo
35.9 x 24.6 x 1.89 cm
Starting at 2.04 kg
65 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer; HP Command Center
Pre-installed software
iQiyi
