HP ENVY - 17-bw0003ca Product Specifications
4BQ21UA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
NVIDIA® GeForce® MX150 (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
41.6 x 27.8 x 2.31 cm
2.9 kg
65 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Bang & Olufsen, dual speakers
