3VN50UA
HP Pavilion - 15-cs0078nr
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Flash cache
16 GB
Video graphics
1 TB 5400 rpm SATA
15.6" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only)
36.16 x 24.16 x 1.79 cm
1.92 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY, dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion - 15-cs0078nr Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP ePrint; HP Games by WildTangent; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Pre-installed software
Netflix
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
