    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 17-ca0002au Product Specifications
4DQ37PA
AMD Ryzen™ 5 2500U Quad-Core (2 GHz base frequency, up to 3.6 GHz burst frequency, 6 MB cache)
Video graphics
AMD Radeon™ Vega 8 Graphics
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
17.3" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
41.48 x 27.22 x 2.45 cm
Starting at 2.34 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
McAfee LiveSafe™ 30-day free trial offer
