3WE41UA
HP ENVY - 17-ae110nr
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
NVIDIA® GeForce® MX150 (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
Optical drive
DVD-Writer
17.3" diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
41.6 x 28.3 x 2.33 cm
3.06 kg
90 W AC power adapter
3-cell, 55.8 Wh Li-ion
HP Wide Vision HD IR Camera with integrated dual array digital microphone
Bang & Olufsen, dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY - 17-ae110nr Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer;
Pre-installed software
CyberLink Power Media Player; Netflix;
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
