4CC25PA
OMEN by HP - 17-an100tx
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
1 TB 7200 rpm SATA
17.3" diagonal FHD 144 Hz IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size backlit keyboard with numeric keypad and NKRO
Pointing device
1 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 Mini DisplayPort™; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone-in
42.3 x 30.4 x 3.3 cm
Starting at 3.73 kg
230 W AC power adapter
8-cell, 86 Wh Li-ion
Bang & Olufsen, dual speakers, HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
OMEN by HP - 17-an100tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; OMEN Command Center; HP Connection Optimizer
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
