    Fix HP Printer issue on macOS
OMEN by HP - 15-dc0008tx Product Specifications
4LE28PA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1050 Ti (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size 2-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
1 HDMI 2.0; 1 headphone/microphone combo; 1 microphone-in; 1 Mini DisplayPort™; 1 RJ-45; 1 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge)
36 x 26.3 x 2.5 cm
Starting at 2.33 kg
150 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost 2.0, DTS Headphone:X™ support
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; OMEN Command Center; HP Connection Optimizer
Pre-installed software
iQiyi
