HP LaserJet Managed E50045 - Load paper to Trays 2, 3, 4, and 5
The following information describes how to load paper in Tray 2 and the optional 550-sheet trays (part number F2A72A). These trays hold up to 550 sheets of 75 g/m2 paper.
The procedure to load paper for the 550-sheet trays is the same as for Tray 2. Only Tray 2 is shown here.
The paper guides may be locked before use and may not be adjustable.
Do not extend more than one paper tray at a time.
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Before loading paper, adjust the paper-width guides by squeezing the adjustment latches and sliding the guides to the size of the paper being used.
    Figure : Adjust the guides
  3. Adjust the paper-length guide by squeezing the adjustment latch and sliding the guide to the size of the paper being used.
  4. To load legal-size paper into the tray, squeeze the lever on the back of the tray that is to the left of center, and then extend the tray back to the correct paper size.
    This step does not apply to other paper sizes.
  5. Load paper into the tray. For information about how to orient the paper, see Tray 2 and the 550-sheet trays paper orientation.
    Do not adjust the paper guides tightly against the paper stack. Adjust them to the indentations or markings in the tray.
    To prevent jams, adjust the paper guides to the correct size and do not overfill the tray. Be sure that the top of the stack is below the tray full indicator, as shown in the enlargement in the illustration.
    Figure : Load paper
  6. Close the tray.
    Figure : Close the tray
  7. The tray configuration message displays on the printer control panel.
  8. If the paper size and type shown is not correct, select Modify to choose a different paper size or type.
    For custom-size paper, specify the X and Y dimensions for the paper when the prompt displays on the printer control panel.
    Figure : X and Y dimensions
When using paper that requires a specific orientation, load it according to the information in the following table.
The Alternative Letterhead Mode settings affects the way to load letterhead or preprinted paper. This setting is disabled by default. When using this mode, load paper as for automatic duplex printing. For more information, see Use alternative letterhead mode.
Paper type
Single-sided printing
Duplex printing and Alternative Letterhead Mode
Letterhead, preprinted, or prepunched
Face-down
Top edge at the front of the tray
Face-up
Bottom edge at the front of the tray
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus.
Enable Alternative Letterhead Mode by using the printer control-panel menus
  1. From the Home screen on the printer control panel, swipe from right to left until the Settings menu displays. Touch the Settings icon to open the menu.
  2. Open the following menus:
    • Manage Trays
    • Alternative Letterhead Mode
  3. Select Enabled, and then touch the Save button or press the OK button.
