HP LaserJet Managed E50045 - Printer views
Printer front view
    Figure : Printer front view
  1. Top cover (access to the toner cartridge)
  2. Easy-access USB port. Insert a USB flash drive for printing without a computer or to update the printer firmware. An administrator must enable this port before use.
  3. Standard output bin
  4. On/off button
  5. Control panel with color touchscreen display
  6. Hardware integration pocket for connecting accessory and third-party devices. To use the hardware integration pocket (HIP), install the HP internal USB ports accessory (B5L28A). The USB port inside the HIP is not functional otherwise.
  7. Formatter cover
  8. Tray 2
  9. Model name
  10. Tray 1
Printer back view
    Figure : Printer rear view
  1. Rear door (access for clearing jams)
  2. Serial number and product number label
  3. Top-cover-release button
  4. Dust cover for Tray 2 (flips up when legal-size paper is loaded)
  5. Power connection
  6. Formatter (contains the interface ports)
Interface ports
    Figure : Interface ports
  1. Slot for a cable-type security lock
  2. Local area network (LAN) Ethernet (RJ-45) network port
  3. Hi-Speed USB 2.0 printing port
  4. USB port for connecting external USB devices (this port might be covered). For easy-access USB printing, use the USB port near the control panel.
Control-panel view
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by selecting the Home button.
The features that appear on the Home screen can vary, depending on the printer configuration.
    Figure : Printer control panel
  1. Reset button
  2. Sign In or Sign Out button
  3. Information button
  4. Help button
  5. Current time
  6. Applications area
  7. Home-screen page indicator
  8. Home button
How to use the touchscreen control panel
Use the following actions to use the printer touchscreen control panel.
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
