HP Color LaserJet Managed E55040 - Printer views
Printer front view
Locate features on the front of the printer.
    Figure : Printer front view
  1. Standard output bin
  2. Control panel with color touchscreen display
  3. Hardware integration pocket for connecting accessory and third-party devices
  4. Easy-access USB port. Insert a USB flash drive for printing without a computer or to update the printer firmware. An administrator must enable this port before use.
  5. Right door (access to the fuser and for clearing jams)
  6. Tray 1
  7. Model name
  8. Tray 2
  9. Front door (access to the toner cartridges)
  10. On/off button
Printer back view
Locate features on the back of the printer.
    Figure : Printer back view
  1. Toner-collection-unit door
  2. Formatter (contains the interface ports)
  3. Power connection
  4. Serial number and product number label
  5. Formatter cover
Interface ports
Locate the interface ports on the printer formatter.
    Figure : Interface ports
  1. Local area network (LAN) Ethernet (RJ-45) network port
  2. Hi-Speed USB 2.0 printing port
  3. USB port for connecting external USB devices (this port might be covered). For easy-access USB printing, use the USB port near the control panel.
Control-panel view
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by touching the Home button .
The features that appear on the Home screen can vary, depending on the printer configuration.
    Figure : Printer control panel
  1. Reset button
  2. Sign In or Sign Out button
  3. Information button
  4. Help button
  5. Current time
  6. Applications area
  7. Home-screen page indicator
  8. Home button
How to use the touchscreen control panel
Perform the following actions to use the touchscreen control panel on the printer.
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
