HP LaserJet Managed MFP E52545 - 31.13 jam error in the document feeder
The following information describes how to clear paper jams in the document feeder. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 31.13.00
  • 31.13.01
  • 31.13.02
  • 13.13.13
  1. Lift the latch to release the document-feeder cover.
    Figure : Lift the latch
  2. Open the document-feeder cover.
    Figure : Open the document-feeder cover
  3. Remove any jammed paper from the document feeder.
    Figure : Remove jammed paper
  4. Lift the document-feeder input tray.
    Figure : Lift the document-feeder tray
  5. Remove any jammed paper below the document-feeder input tray.
    Figure : Remove the jammed paper
  6. Lower the document-feeder input tray.
    Figure : Lower the document-feeder input tray
  7. Close the document-feeder cover.
    Verify that the latch on the top of the document-feeder cover is completely closed.
    Figure : Close the document-feeder cover
To avoid jams, make sure the guides in the document-feeder input tray are adjusted against the document, without bending the document. To copy narrow documents, use the flatbed scanner. Remove all staples and paper clips from original documents.
Original documents that are printed on heavy, glossy paper can jam more frequently than originals that are printed on plain paper.
