4JD41PA
HP Pavilion - 15-cs0038tx
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
500 GB 5400 rpm SATA
15.6" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only)
36.16 x 24.56 x 1.79 cm
1.85 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion - 15-cs0038tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
