HP Notebook - 15g-dx0001ax Product Specifications
4HX79PA
AMD A6-9225 Dual-Core (2.6 GHz base frequency, up to 3 GHz burst frequency, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
500 GB 5400 rpm SATA
15.6" diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
