HP LaserJet MFP M72625, M72630 - Removal: Toner cartridge
This document provides the procedures to remove the toner cartridge.
Click the following link to view a video that demonstrates how to remove the toner cartridge:
Reverse the removal steps to install the assembly.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Toner cartridge part number
JC02-00140A
Toner - Black
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
When the power is turned on, listen for normal startup sounds.
Check the control-panel display for error messages.
Make sure that the printer initializes to a Ready state.
Copy, scan, or print a document. Verify the document copies, scans, or prints correctly.
Remove the toner cartridge
  1. Rotate the dial on the front of the toner cartridge to the left (callout 1) until it stops, and then slide the toner cartridge out of the printer (callout 2).
    When reinstalling the toner cartridge, slide the cartridge into the printer only until the front of the cartridge is even with the front of the cartridge slot. Do not slide the cartridge all the way in the printer. Move the cartridge slightly in or out of the printer until you can rotate the dial to the right until it stops. Do not force the rotation of the dial.
    Figure : Remove the toner cartridge
