HP LaserJet MFP M72625dn, HP LaserJet MFP M72630dn - Printing a fax report
You can set the printer to print a report whether a fax transmission and reception is successfully completed or not.
If a report contains characters or fonts that the printer do not support, Unknown could be printed instead of the characters/fonts in the report.
  1. Press Machine Setup > Application Settings > Fax Settings > Report from the display screen.
  2. Press Fax Send Confirmation from the display screen.
  3. Press the appropriate option.
    • Never: Disables this feature.
    • Always: Activates this feature.
    • On Error Only: Prints a report only when a transmission fails.
  4. Press (Back) to go back to the previous screen.
