    Fix Windows 10 Update Issues
    Are you working from home?
HP Z27 27-inch 4K UHD Display Specifications
Product image
Figure : HP Z27 27-inch 4K UHD Display
Panel
Specification
Display panel type
IPS with LED backlight
Display size (diagonal)
27.0 in
68.58 cm (27.0 in)
Panel active area (W x H)
59.67 x 33.56 cm (23.49 × 13.21 in)
Aspect ratio
16:9
Resolution (native with speed)
3840 x 2160 at 60 Hz (4K UHD)
Viewing angle (typical)
Up to 178° horizontal
Up to 178° vertical
Brightness (typical)
350 cd/m2
Contrast ratio
Static
1300:1 (typical)
910:1 (minimum)
Dynamic
5,000,000:1 (typical)
Response time
8 ms (on/off)
Pixel pitch
0.1554 x 0.1554 mm
Pixels per inch (PPI)
163
Panel bit depth
10-bit (8+2 bit FRC)
Default color temperature
sRGB D65
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut
99% sRGB
Low blue light modes
Yes
Anti-glare
Yes
Special features
Picture-in-Picture (PIP)
Picture-by-Picture (PBP)
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu
Viewing mode
Next Active Input
Power
User-assignable function buttons
3
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-Screen Display (OSD) user controls
Brightness, Contrast, Color Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset VESA graphic modes (noninterlaced)/supported resolutions
640 x 480 at 60 Hz
720 x 400 at 70 Hz
720 × 480 at 60Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 768 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
2560 x 1440 at 60 Hz
2560 x 1600 at 60 Hz
3840 × 2160 at 30Hz
3840 × 2160 at 60Hz
Vertical scan range
Up to 60 Hz
Horizontal scan range
Up to 135 kHz
Pixel clock (maximum)
533.25 MHz
I/O ports/cables
Specification
USB
USB Type-C
2 (1 upstream, 1 downstream)
USB Type-A
2 (downstream)
Video
(1) HDMI 2.0
(1) Mini DisplayPort 1.2
(1) DisplayPort 1.2
HDCP 1.4 for DisplayPort and HDCP 2.2 for HDMI.
Audio
(1) Audio output jack
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +23° vertical
VESA mount
100 mm VESA mount
Security lock-ready
Yes
Power
Specification
Power supply
Internal
Input power
100 to 240 VAC at 50/60 Hz
Maximum power
185 W
Typical power
70 W
Sleep power
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
61.41 x 23.0 x 50.98 cm (24.18 x 9.06 x 20.07 in)
Unpacked without stand (head only)
61.41 x 5.45 x 36.54 cm (24.18 x 2.15 x 14.39 in)
Packaged
72.4 x 32.2 x 48.0 cm (28.5 x 12.7 x 18.9 in)
Unpacked
9.38 kg (20.68 lb)
Packed
11.61 kg (25.6 lb)
Head only
6.21 kg (13.69 lb)
What's in the box?
Specification
Monitor and accessories
HP Z27 27-inch 4K UHD Display Monitor
AC power cord
USB C-to-A data cable
Documentation
User guide and software
HP Display Assistant
Included in CD
Environmental
Specification
Temperature
Operating
5°C to 35°C (41°F to 95°F)
Non-operating
–34°C to 60°C (-29°F to 140°F)
Humidity
Operating
20% to 80% (non-condensing)
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free display backlights
Yes
Eco-label certifications & declarations
EPEAT Gold, (registration varies by country/region)
ENERGY STAR 7
Microsoft WHQL certification (Windows 7, 8, and 10)
CE
CB
KC
KCC
ICE
TUV-S
ISO 9241-307
GS
BIS
EAC
UL
PSB
CCC
CEL
CECP
SEPA
TCO
ISC
VCCI
FCC
BSMI
WEEE
