    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion Gaming 32 HDR Display - Product Specifications
The HP Pavilion Gaming 32 HDR is a 68.6 cm (27 in) Display.
Figure : HP Pavilion Gaming 32 HDR Display
The HP Pavilion Gaming 32 HDR Display
3BZ12AA, 4AJ85AA
Technical specifications
LED feature
Specification
Display size
81.3 cm (32 in) diagonal
Display type
IPS with LED backlight, anti-glare
Panel active area
59.7 x 33.5 cm (23.5 x 13.2 in)
Brightness
600 nits (peak brightness)
300 nits (typical brightness)
Actual performance might vary.
Color gamut
95% DCI-P3
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.276 (H) x 0.276 (V) mm
91.8 PPI
Inputs
1 DVI-D
1 DisplayPort 1.2
2 HDMI
HDCP supported on HDMI.
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Scan range
Horizontal: 115 KHz (approximately 115 K)
Vertical: 48 to 75 KHz
Recommended resolution
2560 x 1440 @ 60 Hz (QHD)
Quad high-definition (QHD) content required to view QHD images.
Aspect ratio
16:9
Static contrast ratio
3000:1
Dynamic contrast ratio
10,000,000:1
Response time
5 ms gray-to-gray (GtG) with overdrive
Power consumption
86 W maximum
Tilt
-5 to +21 degrees
Power supply
External
Dimensions
W x D x H (unpacked):
61.5 x 21.6 x 44.2 cm (24.2 x 8.5 x 17.4 in)
Unpacked: 4.30 Kg (9.48 lbs)
