HP PCs - Advanced Microphone Troubleshooting (Windows 10, 8)
This document applies to HP and Compaq computers and tablets with Windows 10 or 8.
This document provides solutions to a variety of problems that can occur when using microphones.
Before you begin
While troubleshooting the microphone, you might need to disconnect it from the computer. Some USB microphones need to be disconnected according to manufacturer's instructions.
Always follow the manufacturer's instructions for disconnecting USB devices from the computer. Some USB devices must be turned off and/or ejected before they are disconnected from the computer. Other USB devices support the Windows Safely Remove Hardware feature.
Checking the microphone
First, rule out that the microphone problem is not one of the following issues:
  1. Software: If the microphone came with software, make sure it is installed properly and is compatible with your version of Windows.
  2. Power: If the microphone operates on battery power, make sure the batteries are correctly seated and are functional. If the microphone operates on external power, make sure that all the power connections are secure and the power cord is connected to a power source.
  3. Volume: If the microphone has a volume control, make sure it is turned up half way.
  4. Connection: Connect and disconnect the microphone from the computer port.
    • USB connector: If the device uses a USB connector, disconnect, and then reconnect the USB connector to the computer. If the computer still does not recognize the device, try plugging the USB connector into a different port on the computer.
    • Jack connector: If the device uses a jack connector, disconnect, and then reconnect the jack connector to the computer. Make sure the jack connector type you are using is compatible with your computer.
      Two types of connectors are available on HP computers. The connectors are marked with symbols next them.
      • Connectors on the computer marked with only a microphone support input sound only and work with a standard three-pin microphone.
        Figure : Standard three-pin plug
      • Connectors on the computer marked with a headset with a microphone support sound and the use of a microphone when used with a headset with a four-pin plug and a microphone.
        Figure : Four-pin plug
        Four-pin plug
      Some devices use a mini jack connector. This smaller connector is not compatible with HP computers and you might need an adapter to use your device. Also, using an adapter might affect the quality of the audio. This does not mean that your computer has a problem.
      Figure : Example of a jack adapter
  5. Make sure the jack connector is connected to the correct port:
    Digital audio jack ports
    Analog audio jack ports are color coded. Common color coding is shown below, however, colors can vary.
    Newer computers might also have a headset (combination headphones and microphone) port. The headset port has a headset icon next to the port. This port can be used for headsets, headphones, and microphones.
    1. Microphone jack port
    2. Headphones jack port
    Older computers have individual ports, one for the microphone and one for headphones. You can identify the port by the icon next to it.
    Gray, Black and Orange (side, rear, c/sub) are for speakers.
    Pink (mic) is for microphones.
    Green (out) is for headphones.
    Blue (in) is for audio input (like DVD players, tape players, and other sound producing devices).
    • If the computer recognizes the microphone, and it now functions correctly, the problem is resolved.
    • If the computer does not recognize the microphone, continue to Step 6 of this section.
    • If the computer recognizes the microphone, but, it still does not function correctly, continue to Step 6 of this section.
  6. Connect the microphone to an alternative device such as, another computer and try to use it.
    • If the microphone functions correctly when connected to the alternative device, then a driver or computer recognition issue might be causing the problem. Continue to the next section of this document to check for an update to the audio driver.
    • If the microphone does not function correctly when connected to the alternative device, then the microphone might need to be replaced.
Updating the audio driver
Updating the audio driver can resolve many microphone issues. Use the following steps to check for and install audio driver updates:
  1. Connect to the Internet.
  2. In Windows, search for and open Device Manager.
  3. Double-click Sound, video and game controllers.
  4. Right-click the name of the sound hardware and select Update Driver Software.
    Figure : Update Driver Software option in Device Manager
  5. Click Search automatically for updated driver software and wait for Windows to update the driver software.
    Figure : Updated Driver Software: Search automatically for updated driver software
  6. Windows checks to see if updated driver software is available.
    If an update is available, let Windows install the update.
  7. When the update is installed successfully, a Windows has finished installing the driver software for this device window displays.
    Test the microphone.
  8. If updating the driver did not resolve the issue, continue to the next section.
Using the Troubleshooting tool
The troubleshooting tool can fix common problems with audio recording. Follow these steps to use the Troubleshooting tool:
  1. In Windows, search for and open Troubleshooting.
  2. Under Hardware and Sound, click Troubleshoot audio recording, then click Next when the Recording Audio window opens.
    Figure : Troubleshoot audio recording
  3. Click Next in the Recording Audio window.
  4. Select the device you would like to troubleshoot, click Next, then follow the on-screen instructions.
    Figure : Select device to troubleshoot
  5. If a recommended action displays, select Apply this fix or Skip this step to continue to search for other problems.
    If your problem has not been resolved, continue to the next section of this document.
Checking the sound settings
There are a number of options in Windows sound settings that need to be configured so that the computer recognizes and works with the microphone. Use the steps below to modify the sound configuration as necessary for your microphone.
Open the Sound window
  1. Connect the microphone to the computer.
  2. In Windows, search for and open Sound.
    The Sound window opens.
  3. Click the Recording tab in the Sound window.
    Figure : Recording tab in the Sound window
  4. Then use the following steps to troubleshoot the microphone.
Step 1: Make sure the computer recognizes the microphone
  1. In the Sound window, click the Recording tab.
  2. Right-click an empty area of the Sound window.
  3. Click Show Disabled Devices and Show Disconnected Devices.
    Figure : Disabled and disconnected devices shown in the Sound window
  4. If the microphone is listed as Currently unavailable or Not plugged in, disconnect it, then reconnect it to the port. If the microphone is still not detected, refer to the Check the microphone section of this document.
  5. Test the microphone by speaking into it.
    Look at the gray bars next to the device name on the Recording tab:
    • If the gray bars next to the device name change to green, the device is active and an audio signal is passing through the microphone port. The issue should now be resolved.
      However, you might still want to make sure the microphone is set as the default microphone using the Step 2: Setting the default microphone section of this document.
    • If the bars remain gray and inactive, the computer is not recognizing a signal. Leave the recording tab open and refer to the Step 2: Setting the default microphone section of this document.
    Figure : Sound window with Recording tab showing a detected signal for the Microphone device
The microphone you want to use might need to be set as the default microphone. Follow these steps to set your microphone as the default microphone:
  1. From the Recording tab of the Sound window, select the port that you want to use. There could be one or more ports.
  2. If the device you want to use contains a small circle with an arrow pointing down, the device is disabled. To enable the device, right-click the device name and select Enable.
    Figure : Enable selection in the Sound window
  3. Click Set Default to make this device the default audio input device.
    Figure : Set Default option in the Sound window
  4. Click OK to make the changes.
Step 3: Checking volume and mute settings
The volume for the microphone might be muted or turned down, making the computer appear unresponsive to the microphone. Use the following steps to check the speaker volume levels for the microphone.
Unplug all other sound devices before performing this step.
  1. From the Recording tab of the Sound window, select an active microphone, then click Properties.
    Recording tab
  2. The Microphone Properties window opens.
  3. Click the Levels tab.
    Figure : Levels tab
    Levels tab
  4. If the Mute button is on, click it to turn off mute. The Volume button should show as a blue speaker without the red circle .
  5. Use the slider bar to raise the Microphone level to at least 75.
  6. If Microphone Boost is available, adjust to +20.0 dB.
  7. Click OK.
Raising the microphone volume level
If the microphone volume is too low, then the microphone levels in Windows might need to be changed. Follow the steps in this section to resolve the issue:
  1. Click the Recording tab.
  2. Select the microphone, then click Properties.
  4. Change the microphone level to 100 and the Microphone Boost to +10.0dB.
    Figure : Levels tab in the Microphone Properties window
  5. Click Apply.
  6. Disconnect and reconnect the microphone.
  7. Check the microphone recording level.
Resolving microphone issues by disabling enhancements
Sometimes microphone and sound enhancements can cause issues with the microphone. Use the following steps to disable microphone enhancements.
  1. Right-click the Volume icon on the taskbar
  2. Select Recording devices.
    Figure : Selecting Recording devices in the volume menu
  3. Double-click the Microphone you are troubleshooting to open the properties page for that device.
    Figure : Recording tab in the Sound settings
  4. Open the Enhancements tab and select Disable All Sound Effect.
  5. Click Apply, click OK, and test the microphone again.
Changing the format of the microphone
Check to see if using a different default audio format fixes your microphone issue.
  4. On the Advanced tab, select any of the 16-bit options in the list.
    Figure : Changing the default format of the microphone
Resolving microphone issues when running more than one application at a time
Microphone problems can occur when running more than one application at a time. For example, talking on a headset while playing an online game. To improve microphone function when using more than one application at a time, follow these steps:
  1. In Windows, search for and open Sound.
  2. Click the Recording tab.
  3. Select the microphone, then click Properties.
  4. Click the Advanced tab.
  5. Remove the check from the box next to Allow applications to take exclusive control of this device.
    Figure : Advanced properties tab in the Microphone Properties window
  6. Click Apply.
  7. Disconnect and reconnect the microphone. Then check the microphone recording level.
Testing a microphone using Voice Recorder (Windows 10)
Use Voice Recorder to find out if the computer can record a signal from the microphone and play it back. Use the following steps to create an audio file:
  1. Plug the microphone into the computer.
  2. In Windows 10, search for and open Voice Recorder.
    The recorder opens.
    Figure : Voice Recorder window
  3. Click the microphone icon to start the recording. Then, speak into the microphone.
  4. When finished recording, click Stop Recording in the center of the blue circle.
    Figure : Stop recording
    Stop recording
  5. Right-click Recording, then select Open file location.
    Figure : Open file location
    Open file location
    The recording is automatically saved to Sound recordings in your Documents folder.
    Figure : Sound recordings folder
  6. Double-click the filename of your recording. When the Groove Music app opens, click the Play icon ( ) to listen to the recording.
    Figure : Groove Music App
    Groove Music App
Testing a microphone using Windows Sound Recorder (Windows 8)
Use the Windows Sound Recorder to find out if the computer can record a signal from the microphone and play it back. Use the following steps to create an audio file:
  2. In Windows 8, search for and open Sound Recorder.
    Two Sound Recorder options display in the search results list. Select the Sound Recorder option next to the gray microphone icon ().
    Figure : Selecting Sound Recorder from the search list
    The Sound Recorder opens.
  3. Click Start Recording, then speak into the microphone.
    Figure : Sound Recorder initial screen
  4. When finished recording, click Stop Recording.
    Figure : Sound Recorder while recording
    A Save as screen automatically opens.
  5. Type a filename and click Save. A WAV or WMA file is created in the OneDrive Documents folder.
    Figure : Sound Recorder Save As screen
  6. Find and double-click the filename of your recording to play back the recorded sound. The file should play from the sound software that is associated with the audio file type. You can open the sound file using Windows Media Player.
    Figure : Windows Media Player option
Microphone does not work with Skype or other Internet software
If the microphone is not working with Skype, the wrong microphone might be selected as the default. Open the Sound window, then use the steps in the Setting the default microphone section of this document.
Microphone fails after a webcam or a USB microphone is installed
To use the microphone on a webcam or a USB microphone, it might need to be configured separately using the software that came with the device. Make sure the USB device and any associated software is compatible with your version of Windows. If you want to use a different microphone than the USB microphone or webcam, open the Sound window, then follow the steps in the Setting the default microphone section of this document.
Bang & Olufsen: Microphone does not record unless you are directly in front of the PC
With the Bang & Olufsen audio microphone, the microphone does not recognize or record voice unless the speaker is sitting directly in front of the notebook. To correct this, use the following steps.
  1. Open the Bang & Olufsen Audio application and select Input.
    Figure : Bang & Olufsen Audio app showing the Input settings
  2. To reduce background sounds and optimize the microphone for multiple voices, select Multiple voices. The Multiple voices setting has a wider range than the Only my voice setting.
    Figure : Selecting the Multiple voices setting
USB ports not recognized
Sometimes a USB-connected headphone and headset do not work because of a problem with the USB ports on the computer. If you have not been able to resolve the problem after trying the steps in this document, then go to Troubleshooting USB Connections (Windows 10, 8).
