    Windows 11 Upgrade Guide
Product Specifications for the HP LaserJet Pro M15w Printer (W2G51A)
Product naming
Model name
W2G51A
What's included and accessories
What's in the box
HP LaserJet Pro M15w Printer; Preinstalled HP Original Introductory Black LaserJet Toner Cartridge (~500 pages); Getting Started Guide; Setup Poster; Support flyer; Warranty guide; Software drivers and documentation on CD-ROM; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port; built-in Wifi 802.11b/g/n
Wireless capability
Yes
Environmental
Acoustic power emissions
6.5 B(A)
Operating humidity range
30 to 70% RH
Non-Operating Humidity Range
10 to 90% RH
Recommended operating temperature range (Celsius)
17.5 to 25ºC
Recommended operating temperature range (Fahrenheit)
62.6 to 77ºF
Storage temperature range (Celsius)
-20 to 60ºC
Storage temperature range (Fahrenheit)
-4 to 140ºF
Environmental specifications
Mercury-free
Memory
Memory
16 MB
Maximum Memory
16 MB
Mobile printing capability
Mobile printing services
Apple AirPrint; Google Cloud Print 2.0; Mopria-certified; Wi-Fi Direct, HP Smart App
Mobile printing compatibility note
Apple AirPrint -Mobile device must have AirPrint. Wireless operations are compatible with 2.4 GHz operations only. Learn more at hp.com/go/mobileprinting. Google Cloud Print 2.0- Requires Google Cloud Print registration and Google account. Wireless operations are compatible with 2.4 GHz operations only. Learn more at hp.com/go/mobileprinting.
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; IP Direct Mode; LPD; SLP; Bonjour; WS-Discovery; BOOTP/DHCP/AutoIP; SNMP v 1/2/3;HTTP/HTTPS
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6; envelopes (C5, DL); custom
Media sizes supported (U.S. standard)
Letter, envelopes (No. 10); custom
Media sizes, custom (metric)
105 x 148 to 216 to 297 mm
Media sizes, custom (U.S. standard)
4.13 x 5.83 to 8.5 x 11.69
Media types
Plain paper, envelope, postcard, Label
Media weight supported (metric)
65 to 120 g/m²
Media weight supported (U.S. standard)
17 to 32 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
346 x 348 x 280 mm
Maximum dimensions (W x D x H, U.S. standard)
13.6 x 13.7 x 11 in
Weight (metric)
3.8 kg
Weight (U.S. standard)
8.4 lb
Power
Energy savings feature technology
HP Auto-on/Auto-off Technology
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the product warranty.
Power supply
110V - 127V nominal @ +/-10% (min 99V, max 140V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz), 220V - 240V nominal @ +/-10% (min 198V, Max 264V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz)
Power consumption
210 watts (active printing), 2.2 watts (ready), 0.4 watts (sleep), 0.1 watts (Manual-off), 0.1 watts (Auto-off/Manual-on), 0.4watts (Auto-off/Wake on USB)
Print cartridges
Number of print cartridges
1 Black
Replacement cartridges
HP 48A LaserJet Black Toner Cartridge (~1000 pages)
Replacement cartridges footnote
Declared yield value in accordance with ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. Only available with Original HP supplies; Internet access required. To learn more, visit http://www.hp.com/go/SureSupply
Printing specifications
Print technology
Laser
Print resolution (best)
Up to 600 x 600 x 1 dpi
Maximum print area (metric)
216 x 297 mm
Maximum print area (U.S. standard)
8.5 x 11.7 in
Monthly duty cycle
Up to 8000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
Apple AirPrint, Mopria-certified, HP Auto-On/Auto-Off, Wi-Fi Direct, HP Smart App
Regulatory specifications
Regulatory model number
SHNGC-1700-01
Energy efficiency
ENERGY STAR qualified; EPEAT®Silver
Safety
IEC 60950-1:2005 +A1:2009+A2:2013/EN60950-1:2006 +A11:2009 +A1:2010+A12:2011+A2:2013; IEC 60825-1:2014 / EN 60825-1:2014 (Class 1 Laser/LED Product); IEC 62479:2010 / EN 62479:2010; GB4943-2011
Electromagnetic compatibility
CISPR 22:2008 & CISPR 32: 2012/ EN 55032:2012 - Class B, EN 61000-3-2: 2014, EN 61000-3-3: 2013, EN 55024: 2010, FCC Title 47 CFR, Part 15 Class B/ICES-003, Issue 6, GB9254-2008, GB17625.1-2012
Security
Security management
Password-protected network embedded Web server; enable/disable Network ports; SNMPv1 community password change
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer.
Minimum System Requirements for Macintosh
AppleOS X EI Capitan (v10.11) macOS Sierra (v10.12) macOS High Sierra, (v10.13); 1.5 GB HD; Internet required; USB
Compatible Network Operating Systems
Windows10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. AppleOS X EI Capitan (v10.11) macOS Sierra (v10.12) macOS High Sierra, (v10.13); 1.5 GB HD; Internet required; USB Linux (For more information, see https://developers.hp.com/hp-linux-imaging-and-printing)
Operating system (supported note)
Not all "Compatible Operating Systems" are supported with INBOX software; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
One-year limited warranty
