    Windows 11 Upgrade Guide
HP ENVY x360 - 15-bp118tx Product Specifications
3BA48PA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (4 GB (onboard) and 8 GB (1 x 8 GB))
Video graphics
NVIDIA® GeForce® MX150 (4 GB GDDR5 dedicated)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 2.0a; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge)
Dimensions (W x D x H)
35.97 x 24.88 x 1.96 cm
Starting at 2.04 kg
90 W AC power adapter
3-cell, 55.8 Wh Li-ion prismatic
Bang & Olufsen, dual speakers, HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
