Document ID: c05932423
Version: 1
Realtek WLAN Driver Update on Feb. Refresh
Release date : 15-Feb-2018
Last updated : 15-Feb-2018
DETAILS OF CHANGE
  • Provided software updates for Realtek WLAN driver to fix an issue on a system that automatically connects to a wireless Access Point after the system is restarted which causes Windows to display the message The device doesn't support Miracast, so you can't project to it wirelessly.
  • Provided software updates for Realtek WLAN driver to fix an issue where the Mobile Hotspot function cannot be enabled when the system restarts and automatically connects to a wireless Access Point.
COMPONENT VERSION
v2023.66.1113.2017
REASON FOR CHANGE
To fix the issue of Mobile Hotspot function that are not enabled automatically when the system restarts.
IMPACT OF CHANGE
No impact of change.
Components affected:
Realtek RTL8000 Series Wireless LAN Driver
DATE OF CHANGE
Effective date : 01-Feb-2018
Hardware platforms affected : HP EliteDesk 705 G3 Desktop Mini PC, HP EliteDesk 705 G3 Microtower PC, HP EliteDesk 705 G3 Small Form Factor PC, HP EliteDesk 800 35W G3 Desktop Mini PC, HP EliteDesk 800 65W G3 Desktop Mini PC, HP EliteDesk 800 G3 Small Form Factor PC, HP EliteDesk 800 G3 Tower PC, HP EliteOne 800 G3 23.8 Non-Touch Healthcare Edition All-in-One Business PC, HP EliteOne 800 G3 23.8-inch Non-Touch All-in-One PC, HP EliteOne 800 G3 23.8-inch Touch All-in-One PC, HP EliteOne 800 G3 23.8-inch Touch GPU All-in-One PC, HP ProDesk 600 G3 Desktop Mini PC, HP ProDesk 600 G3 Microtower PC, HP ProDesk 600 G3 Small Form Factor PC, HP ProDesk 680 G3 Microtower PC, HP ProOne 600 G3 21.5-inch Non-Touch All-in-One PC
