Document ID: c05930152
Version: 1
Advisory: HP ZBook x2 G4 Detachable Workstation PCs - Fn+F3 keys, Finger Gestures on Touchscreen and NFC Functions Do Not Work
Release date : 13-Feb-2018
Last updated : 13-Feb-2018
DESCRIPTION
The Fn+F3 keys do not turn on the keyboard backlight, 3 and 4 Finger gesture commands on the touchscreen and NFC (Near Field Communication) functions do not work.
This can occur after performing the following sequence:
  1. Dock the soft keyboard.
  2. Pair the computer with the soft keyboard.
  3. Disable Bluetooth.
  4. Undock the soft keyboard.
  5. Wait 15 seconds for the soft keyboard to enter Sleep mode.
  6. Dock the soft keyboard and wait 20 seconds for the keyboard backlight to turn off.
SCOPE
The information in this document applies to the following:
Computers:
  • HP ZBook x2 G4 Detachable Workstation
Operating Systems:
  • Microsoft Windows 10 Creators Update (RS2)
  • Microsoft Windows 10 Fall Creators Update (RS3)
RESOLUTION
To resolve this issue, download and installed the SoftPaq to update the keyboard firmware to the latest version:
SoftPaq Description
Release Notes
Download SoftPaq
HP Zbook x2 Keyboard Firmware Update
Version: 180110_V0353_A2_V1
Revision: A
NOTE: A more recent version of this software may be available. Check for newer versions at: http://www.hp.com/drivers
Hardware platforms affected : HP ZBook x2 G4 Detachable Workstation
Support Communication Cross Reference ID : IA05930152
