HP LaserJet Enterprise MFP, HP PageWide Enterprise MFP - Additional options when faxing
The following settings are available in the Options list when faxing.
The following list contains the master set of options available for HP LaserJet Enterprise MFP printers. Some options are not available on all printers.
Original Sides
Specify whether the original document is printed on one side or both sides.
Resolution
Specify the resolution of scanned images. Select a higher resolution to increase the clarity of the image. However, as the resolution increases, the file size also increases.
Original Size
Specify the paper size for the original document.
Content Orientation
Specify whether the original document is printed in Portrait or Landscape orientation.
Image Adjustment
Sharpness: Clarify or soften the image. For example, increasing the sharpness could make text appear crisper, but decreasing it could make photos appear smoother.
Darkness: Increase or decrease the amount of white and black used in colors in scanned images.
Contrast: Increase or decrease the difference between the lightest and the darkest color on the page.
Background Cleanup: Remove faint colors from the background of scanned images. For example, if the original document is printed on colored paper, use this feature to lighten the background without affecting the darkness of the image.
Automatic Tone: Available for Flow printers only. For original documents that have at least 100 characters of text on the page, the printer can detect which edge is the top of the page, and it orients the scanned images appropriately. If some of the pages are upside-down in relation to the other pages, the resulting scanned image has all pages right-side-up. If some of the pages have a landscape orientation, the printer rotates the image so that the top of the page is at the top of the image.
Optimize Text/Picture
Optimize the job for the type of image being scanned: text, graphics, or photos.
Erase Edges
This feature is not available for all firmware versions. You might need to update the printer firmware to use this feature.
Remove scan defects such as dark borders, staple marks, or hole-punch marks by “erasing” the specified edges of the scan job.
Blank Page Suppression
Exclude blank pages in the original document from scanned images. This feature is useful for scanning pages printed on both sides to eliminate blank pages in the resulting scanned document.
Multi-feed Detection
Enable or disable multi-feed detection. When enabled, scanning stops when the printer detects more than one page at a time being fed in the document feeder. When disabled, scanning continues when a multi-feed is detected, to allow scanning pages that are stuck together, originals with self-adhesive notes on them, or thick paper.
Notification
Select whether to send notifications of the status of scan jobs. The printer can print the notification, or it can send the notification in an email.
