HP LaserJet Job Aids
This PDF portfolio contains individual “how to” job aids to help you use your HP LaserJet printer. The job aids provide instructions for the following tasks:
  • Printing
  • Copying
  • Scanning
  • Faxing
  • Clearing jams
Save and print from this PDF Portfolio
A PDF Portfolio contains multiple files assembled into one large PDF. You can print the entire portfolio, and you can save or print individual files within the portfolio.
To extract (save) a specific job aid:
  1. Select the job aid you want, and make sure Layout mode is selected on the top menu bar.
  2. Select the Extract File icon on the right side of the job aid, select the location where you want to save the file, and then select Save.
    Extracting a file does not remove it from the PDF Portfolio.
To print one or more job aids in this PDF Portfolio:
  1. Open the PDF Portfolio. To print only certain PDFs, select those PDFs.
  2. Select File, select Print, and then choose one of the following:
    • All PDF Files (Prints all the PDFs in the PDF Portfolio.)
    • Selected PDF Files (Prints the selected PDFs. This option is available only if you have selected one or more specific PDFs in the portfolio.)
  3. Choose applicable printing options, and then select Print or OK.
    The files print in alphabetical order, regardless of the order presented in the portfolio view.
Customize this PDF Portfolio (optional)
You may use Adobe® Acrobat® Pro to customize these job aids to add company logos or photos, and to export content to Microsoft® Word. However, edits to the original text and graphics require written permission from HP, Inc.
